Re: SM Carb Help Please
Posted by CNKS on August 04, 2013 at 19:28:23 from (216.144.104.128):
In Reply to: Re: SM Carb Help Please posted by pete_5959 on August 04, 2013 at 16:37:03:
In that case you either have an M carb or a SM carb that has M parts in it. If the choke lever is on the outside it is an M carb, inside it is a SM carb.
