Posted by pete_5959 on August 04, 2013 at 16:37:03 from (70.63.206.178):
In Reply to: SM Carb Help Please posted by Pete_5959 on August 04, 2013 at 05:55:04:
I found my Blue Ribbon book on the fuel system and with a slight adjustment of the low speed idle screw inside governor the rpm dropped to 400. Checked hi speed and it is dead on at 1600. increased rpm to 420 with idle adjust screw. All is well! Now as for the Main Jet screw no way can I set that to 5 full turns out. Way to rich and barely stays running. 2 1/2 turns and purrs like a kitten? Carb has been cleaned and rebuilt with Case IH parts. I'll just leave well enough alone. Thanks for the guidance and recommendations on refreshments to get me through the task at hand.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
