removing the rod to support the brake and clutch levers
Posted by HicksDale on August 06, 2013 at 16:53:06 from (75.229.7.190):
I want to remove the rod that the clutch and brake
levers are mounted on for a M. I have a manual for
an H and it looks like it goes through the tractor
housing with nothing inside to keep it from simply
slipping out. Is that correct?
Thanks for responses. DH
