Re: removing the rod to support the brake and clutch levers
Posted by Rick Remmert on August 07, 2013 at 18:10:40 from (68.103.4.23):
In Reply to: removing the rod to support the brake and clutch levers posted by HicksDale on August 06, 2013 at 16:53:06:
I don't know about this tractor, but on the C, you have drain the rear end oil out or you will get a bath. Someone will know on here.
