Posted by anvilheadtexas on August 06, 2013 at 17:22:44 from (99.117.216.44):
Okay - after hooking up 6 volt positive ground battery to teh battery cables AND NOT the jumper cables, my cub cranks fine. The next step is to wire so I can see if I get spark. I am going to by pass the ignition and ampmeter cause I already dismantled the dash. I only want to see if I can get spark and then maybe fire....then I strip down the rest of the way.
Question...if I by pass the dash, I will wire from the starter directly to the regulator BAT. Then the wire coming out of the regulator from I will go directly to the negative terminal on the coil.
I realize that the current will be constant to the coil so I will build in a temp switch somewhere in circuit.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
