Re: Temporary Wiring - 1951 Cub
Posted by old on August 06, 2013 at 19:06:13 from (209.86.226.27):
In Reply to: Temporary Wiring - 1951 Cub posted by anvilheadtexas on August 06, 2013 at 17:22:44:
Just run a simple hot wire as in since it is + ground a wire from the - side of the battery to the coil. That way you know if it will fire or not and if you hook it up the right way if something goes wrong it is a simple pull hard to pull it off. Run many an old engine that way. By the way if when you hook up the hot wire you notice a spark then you know the points are working if a distributor type system. If no spark the points are open of need some TLC
