1951 Cub - Problem Discovered Tonight
Posted by anvilheadtexas on August 07, 2013 at 22:14:21 from (99.117.216.44):
third party image
third party image
Did not check to see if the guage showed oil pressure...as I said, I am a rookie.
I did discover that the tractor was difficult to put into gear...lots of grinding...so I stopped trying.
I also discovered that the rear "pto" pulley shaft came loose when I attempted to put the tractor in gear.
See picture.
So I loosened the bolts to see what was up. It appears the shift toggle has come lose from the shaft.
I also noted that the gear oil was low...and past its useful life. Any recommendations what I do.
My plan tommorow is to check oil pressure and do whatever anyone suggests.
