Before you start the engine again, prime the oil pump.
Remove the cap from the oil filter housing. At the top, inside the housing will be a hole going into the block. Squirt plenty of oil in that hole. With the ignition off, turn the engine over till oil comes back out the hole. Repeat if necessary. When the oil pumps out the hole, the pump is primed and you can put it back together and run it. It may take a few seconds after the engine starts for the pressure to register.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
