Farmall C Front Wheel Slop
Posted by C. Amick on August 08, 2013 at 14:06:11 from (173.224.156.121):
The tractor has a narrow front. There is quite a bit of play between the inner wheel bearing and the hub. I couldn"t see anything wrong with the bearing. I tightened the axle nut as tight as I could against the outside bearing. I guess the hub is worn? I can"t see how the bearing could be worn? Any suggestions for taking up the slack? I guess it will probably last a long time the way it is.
