Tapered roller bearings cannot be run with "as much as I could" preload. Tyhey will be toast in short order. If loose after tightening, there is a bearing out. Running it will destroy the spindle and thus the lower bolster. Not good!!. Take it apart and find the real issue. It should have preload as follows. With the other tire on a 4X4 to lift the wheel that is loose, replace bearings and seals as needed. Pack the bearings with wheel bearing grease. Assemble. Tighten the spindle nut till the wheel just starts to feel some drag as it is turned by hand. Whack the casting of the wheel with a wooden 2X4 to seat the bearings. Check the spin again if loose retighten the nut till it will only spin on its own about one turn after a good hand spin. Loosen the nut one castle and pin it there. Jim
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
