Re: Farmall Super C - Carburetors - air cleaner
Posted by Janicholson on August 08, 2013 at 15:23:46 from (67.167.73.21):
In Reply to: Farmall Super C - Carburetors - air cleaner posted by carpenter on August 08, 2013 at 15:19:05:
The choke should be all the way in. If it is even part way out it will prevent carb adjustment. High speed circuit probably still has goo in it preventing proper flow. Though not adjustable, with clean passages and jets, they are just fine. Float level is critical.
Adjust the valves when it will run W/O the choke. Jim
