Farmall Super C - Carburetors - air cleaner
Posted by carpenter on August 08, 2013 at 15:19:05 from (98.240.173.82):
Just brought this C home. Normal neglected areas. Have The books. The carb does not have a load screw, only idle. Do others find this a problem ? Will a clean serviced air cleaner crate enuff restriction to richen the mix ?
After a Couple wasted days with this C it runs pretty good and is ready for my intended purpose.
I find it runs better with the choke closed a bit. The air cleaner is not installed.
It has a zenith carb and new tune up. Rebuilt carb by me. Have not done a compression test.
It runs better under load than not. Adjusting idle has some effect. Starts fast.
Bottem line is I want it to idle better. Shoud I focus on the carb or maybe valves ?
