Re: B275 diesel
Posted by jdemaris on August 08, 2013 at 15:34:41 from (70.215.1.170):
In Reply to: B275 diesel posted by Glenn D on August 08, 2013 at 15:17:23:
Is it an older B-275 with the air-governor and in-
line CAV pump? I've got two like that and both
spit oil or diesel out that pigtail. Done it for
20 years now and never bothered a thing.
The in-line pump is supposed to be kept full of
motor oil. When the diesel pump plungers leak a
bit internally, the pump's crankcase gets
overfilled and the excess comes out that little
pigtail. I drain mine once in awhile and fill
back with motor oil. Been fine.
If you really want to fix perfect - I know a place
in England that still sells new pump plungers and
pistons. Big waste of money though as I see it if
the tractor still runs OK.
