Re: Farmall Super C - Carburetors - air cleaner
Posted by CNKS on August 08, 2013 at 18:23:25 from (216.144.104.128):
In Reply to: Farmall Super C - Carburetors - air cleaner posted by carpenter on August 08, 2013 at 15:19:05:
Usually the C113/123 are too rich to begin with unless they are used for a long period of time. Short time periods result in carbon buildup. I think your carb needs to be cleaned again--disassemble and soak in real carb cleaner overnight. As Jim says if you need the choke on something is wrong. Idle is usually not a problem.
