The clearance between the throwout bearing and the shaft is normal.
As others have said, the throwout bearing is fixed in place, and does not spin. The pressure plate fingers "scrub" on the bearing when you depress the clutch pedal.
If you can't get it into gear because it's grinding, the clutch isn't releasing. It doesn't take much for the disk to stick/rust to the flywheel or pressure plate, especially if the tractor hasn't run in 10 years.
Taking it apart you may see nothing obvious but it will likely be fine when you put it back together now.
Before you slide the tractor back together, adjust the height of the release fingers on the pressure plate. IIRC they should be adjusted at 1-1/4" from the main metal surface of the pressure plate to the surface on the fingers that scrubs on the throwout bearing.
After you do that adjust the pedal free play to factory spec. I think that's around 1" as well.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
