Posted by Patrick HMD on August 09, 2013 at 15:41:48 from (75.0.227.170):
I just got an aftermarket waterpump. The brass nut was loose, so I'm not sure how tight it should be up against the packing itself. Any set rule on this?
On the old OEM pump, the brass nut was real tight, but seemed to be working OK with no water leaks.
The only reason I replaced it was that the shaft had very noticeable end play. Wasn't sure if that was right or not, or something in there was wore out. So I decided to retire the old 64 year old pump. I discovered this when I removed it for painting. Minimal end play on the new pump shaft.
Another thing. The 2 zerk fittings. Obviously I'll need to pump some grease in there. How do you know when to stop? I sure as heck don't want any excess grease flinging all over the new paint job.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
