Re: M waterpump brass packing gland, how tight?
Posted by Kevin Meier on August 09, 2013 at 17:15:57 from (70.198.5.226):
In Reply to: M waterpump brass packing gland, how tight? posted by Patrick HMD on August 09, 2013 at 15:41:48:
Snug it up until you feel tension on the shaft when turning. If
it leaks turn it some more. The gland should have a space
under the t bar
