Re: Farmall Super C - Carburetors - air cleaner
Posted by carpenter on August 10, 2013 at 09:30:51 from (98.240.173.82):
In Reply to: Farmall Super C - Carburetors - air cleaner posted by carpenter on August 08, 2013 at 15:19:05:
Installed the super clean redone air cleaner. It indeed did make a differance and I am now satisfied with the idle. Carb probably should be redone though.
