Re: Leaking Oil from side of engine on 706 gas
Posted by MN Scott on August 15, 2013 at 07:06:12 from (184.158.22.204):
In Reply to: Leaking Oil from side of engine on 706 gas posted by Cmore on August 15, 2013 at 05:30:59:
When you replace the gasket make sure you also replace all of the screws that hold the plate on. They are a special sealing screw. If you don't replace them it will continue to leak even with the new gasket.
