Re: Leaking Oil from side of engine on 706 gas
Posted by boomer22 on August 16, 2013 at 09:55:20 from (216.51.197.146):
In Reply to: Leaking Oil from side of engine on 706 gas posted by MN Scott on August 15, 2013 at 07:06:12:
MN Scott said: (quoted from post at 07:06:12 08/15/13) When you replace the gasket make sure you also replace all of the screws that hold the plate on. They are a special sealing screw. If you don't replace them it will continue to leak even with the new gasket.
Just out of curiosity where does one get the gasket and screws?
This post was edited by boomer22 at 09:55:57 08/16/13.
