Farmall A Left or Right Wheel
Posted by jerry stevens on August 15, 2013 at 08:42:02 from (12.170.61.98):
Stupid question I'm sure but need to make sure. I removed the rear wheels from my 52 Farmall A to have the tires removed from the rims for blasting and paint and found the left wheel to be the heavy one and the right one to be the light one. Doesn't the heaviest wheel go on the left and the lightest on the right?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
