Re: Farmall A Left or Right Wheel
Posted by TractormanNC on August 15, 2013 at 08:49:01 from (108.72.58.200):
In Reply to: Farmall A Left or Right Wheel posted by jerry stevens on August 15, 2013 at 08:42:02:
Nope.
Left side is already heavy. The thick cast iron wheel goes on the right side to try to even out the weight from left to right.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
