Re: Checking Oil on M
Posted by duckrock on August 15, 2013 at 12:08:40 from (70.215.78.226):
In Reply to: Re: Checking Oil on M posted by Janicholson on August 14, 2013 at 17:16:02:
I'm following you up until the belly pump. I found the valves today. Top one is intact, but the bottom one is broken off. And, I know where the winged cap is to fill oil. I'm not sure what you are referring to as "bakers hat cap". Found what I saw that might be a dipstick tube I will need to take the sheet metal off to check. Also, not sure if you are saying there are two places that need to be checked or alternative ways to check oil? I appreciated the help.
