Posted by davidrz on August 15, 2013 at 15:03:37 from (216.183.60.107):
There was a post yesterday (8-14-13)related to basically the same problem I am having with a 79 IH Cub.
The tractor sat for almost 10 years and just got it running. The lift was not working, I just simply kept moving the lever back and forth every time I started it and all of a sudden it worked for a few times. Now it has stopped working again, as it was before.
Based on the advice you gave to the other poster, this is what has taken place;
- made sure fluid is a proper lever, used Hy-tran.
- the tractor is all original, so not connections are missing or loose.
- took off allen wrench plug to make sure oil drained and pumping while engine is on.
- when moving lever to the front there is not load on the engine, when moving back there is a very, very minor load. you have to listen carefully to even notice it.
Question - What other advice can you provide. Thank you in advance for you assistance. David
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
