I can give you an experiance I had with mine when it quit working. When I would move the touch control the hydraulic lift would move for a second and then nothing. I rebuilt the touch control unit and had the same thing. I put a new pump on and had the same result. Finally I pulled the front of the engine off and found that the cam gear had moved just enough that it was not engaging the hyd. pump. I put the gear back in place with a little tack weld to keep it from moving. Has worked fine for years.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
