Re: Need help with m cranking issue
Posted by caterpillar guy on August 16, 2013 at 03:53:47 from (75.134.172.124):
In Reply to: Need help with m cranking issue posted by Twiggcas on August 15, 2013 at 05:05:17:
Since he says it will pull start, and turns over without plugs. I vote for the cables being to light. That would cause all the hot items (switch
) and not turn over with the plugs in. If the cables are getting hot definitely the cables.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
