Need help with m cranking issue
Posted by Twiggcas on August 15, 2013 at 05:05:17 from (198.228.200.158):
6 volt ststem Got a 44' farmall m then cranks over good with
spark plugs out, but when plugs in wont! It'll turn maybe 1/8 to
1/4 revolution with plugs in, when I got tractor guy said it had
bent push rod but it was straightened out, it runs if u tow start
it, nit the best but runs(carb needs rebuilding) 2x
had starter checked at a starter shop, tryed 2x brand new 6
volt battery's, new battery cables, tryed 2 new starter buttons
and still same problem, starter button gets hot real quick, also
drained oil and about a gallon too much in her, what is it, could
it be internal mechanic part (bearing) making it to tight turn
over by starter or what? Need help! And has good ground
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
