Re: Need help with m cranking issue
Posted by Nate V. IA on August 16, 2013 at 12:44:25 from (216.51.200.34):
In Reply to: Need help with m cranking issue posted by Twiggcas on August 15, 2013 at 05:05:17:
Unhook your battery from the starter and try jumping the starter from a truck or booster pack, make sure ignition is off and trans is out of gear. 12v won't hurt your 6v starter. Depending on your results follow what the other posters have said.
Nate
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
