Farmall Tractors Discussion Board
Re: Re: Help! H Hydraulics not working.
Posted by C.Fitz on January 18, 1999 at 14:11:57:
In Reply to: Re: Help! H Hydraulics not working. posted by john d. on January 18, 1999 at 08:10:05:
I had the same problem also; if after you've checked the coupler and all else and its still not working; you might have a stripped out impeller inside your pump like I did. I switched pumps with my parts tractor and she worked fine.
Post a Followup
: Re: Re: Re: Help! H Hydraulics not working.
