Farmall Tractors Discussion Board
Re: Help! H Hydraulics not working.
Posted by john d. on January 18, 1999 at 08:10:05:
In Reply to: Help! H Hydraulics not working. posted by Brian Saylor on January 18, 1999 at 07:17:37:
Exactly what happens, or doesn't happen? With the clutch released, and the hydraulic lever pulled, does the pump seem to develop pressure? Any noise? This is a single-acting, or one-way system on these tractors; only one hose goes to a cylinder, not two. If the system is connected as described in the manual, and there is NO noise, NO pressure, NO oil flow, remove the access plate on the bottom of the tractor behind the belly pump and see if the connector is installed between the pump and the transmission. You might also try removing the plug from one port (WITH THE OUTLET TURNED DOWN!) and briefly engage the lever to see if oil comes out.
Post a Followup
: Re: Re: Help! H Hydraulics not working.
