Re: Ih 444 help needed
Posted by Bernard le mecano on August 17, 2013 at 03:16:31 from (207.134.125.137):
In Reply to: Ih 444 help needed posted by john *.?-!.* cub owner on August 16, 2013 at 20:35:42:
Hi, I've see bent push rods on those engine in case of engine overspeed or if the engine is stopped for long time, the valve that are open are stuck and when you re-start the engine the push rod bent or broke. For the pto, it have a bushing in the center of the pto shaft, where the dog engagement. You have to remove the shaft to change the bushing. Bernard in Quebec Canada
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
