Re: Farmall C Voltage Regulator
Posted by John T on August 17, 2013 at 05:52:04 from (216.249.76.176):
In Reply to: Re: Farmall C Voltage Regulator posted by gene bender on August 16, 2013 at 18:50:38:
"Simple test with engine running ground the field on the gen if that shows charge the reg is at fault."
Just to add a bit to that, Id say "if that shows charge the reg is at fault OR ELSE THE REG ISNT WELL GROUNDED (which can be the problem and not allow a charge EVEN IF REG IS FINE) OR ELSE THE WIRE IS BAD FROM FLD ON GENNY TO FLD ON VR"
Fun chat
John T
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
