440 Baler busted jack
Posted by Mike Trick on August 20, 2013 at 14:05:05 from (184.64.150.192):
I drove the jack into the hitch when baling by going thru a ditch over a paved road into another hay field. Did not notice jack had fell down. CNH has no parts, and in western Canada there seems to be no junkyards with balers. Found that the 435/445 series of balers uses a simple support that bolts on under fwd part of the gearcase. The jack is just a simple 1/4 turn pipe jack. This allows hitch to be free and able to be moved when parked. CaseIH does not have that part either. Did some research and found that this support would fit every IH baler from 1963. Phoned CaseIH about getting a drawing on PDF so could produce my own support. CaseIH is hesistant due to it's proprietry. Any advice?
