Re: 440 Baler busted jack
Posted by Janicholson on August 20, 2013 at 14:50:21 from (74.60.94.18):
In Reply to: 440 Baler busted jack posted by Mike Trick on August 20, 2013 at 14:05:05:
Three choices. Have the one you have repaired or duplicated with fresh material.
Find a heavy trailer tongue jack that is sturdy enough and bolts on.
Find a replacement from a scrapped baler. I would go with the replacement using a modern jack. Jim
