Re: Rear end and engine fill levels
Posted by pete_5959 on August 21, 2013 at 07:29:36 from (138.162.128.54):
In Reply to: Rear end and engine fill levels posted by Yooper Farmall on August 21, 2013 at 07:08:04:
Yooper....Yes on the square plug. If overfilled you get what is visible on your tractor a line showing leakage starting at gasket. I would use 140 if your not in the freeze belt. The engine oil level is fine if between the petcocks on oil pan. If you get no oil out the bottom one add until slow seep close and then add one additional quart at which time it should slow seep out the top.
