Posted by carlsandberg on August 24, 2013 at 11:17:28 from (96.126.47.89):
In Reply to: B275 diesel bleed posted by Glenn D on August 24, 2013 at 10:32:06:
Yes, will be hard to start after running dry... remove the fuel line after the injector pump and crank it to remove air up to that point, dont crank solid or you will heat up the starter and then have another problem... maybe try some starting fluid to help it along, I"ve run my diesel out of fuel before and have done this to get it going
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
