B275 diesel bleed
Posted by Glenn D on August 24, 2013 at 10:32:06 from (184.151.61.78):
Does this motor need to be purged of air after running out of fuel? I ran it dry this morning and haven't been able to tell if its getting fuel or not since.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
