Re: B275 diesel bleed
Posted by AJGF on August 24, 2013 at 12:01:05 from (173.180.91.13):
In Reply to: B275 diesel bleed posted by Glenn D on August 24, 2013 at 10:32:06:
Open banjo bolt at spill pipe connection on top of fuel filter, use primer until fuel flows, tighten banjo bolt. Next do the same with inlet connection at top of injector. Next do same with lower vent screw on injector. Next do same with upper vent screw on injector. Repeat last two steps. Next set throttle fully open and slacken all unions at injectors. Turn engine over with starter a few seconds, then tighten injector unions. Start up engine, if it runs uneven, slacken injector unions, one at a time, for a few seconds, then retighten.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
