Re: need help attaching belt pulley to super a farmall
Posted by Haas on August 24, 2013 at 20:07:25 from (50.142.111.41):
In Reply to: need help attaching belt pulley to super a farmall posted by Gilbert Kiser on August 24, 2013 at 12:47:45:
You will have to remove the stud bolts (threaded rods) to mount your woods mower bracket. To remove the studs, take one of the nuts off another bolt and screw it on top of the nut on the stud you want to remove then use two wrenches to jam the nuts together. Put one wrench on the inside nut and screw the stud out of the final drive. This will remove the stud without damaging te threads.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
