Re: cub clutch question
Posted by David Lampman on August 25, 2013 at 05:52:47 from (69.54.29.239):
In Reply to: cub clutch question posted by tedregentin on August 24, 2013 at 20:36:48:
I ran into that with my Super A and was told on this forum that the old graphite one shouldn't be used with a new pressure plate as the graphite "wears in" and may not engage the new pressure plate correctly. Also, in order to use a bearing throw-out you have to buy the housing that the bearing presses onto because the bearing won't fit the graphite housing. I found this to be true and the bearing type is smoother and quieter and well worth the change over.
HTH
