cub clutch question
Posted by tedregentin on August 24, 2013 at 20:36:48 from (216.110.201.79):
My two youngest boys were using my cub to haul hay bales for a neighbor. The clutch quit working and the pedal was low. I looked at the adjustment on the clutch rod and there was no adjustment left. I took the loader off and split the tractor. The flywheel, pressure plate and disc all look good. The throw out bearing looked bad so I looked at YT parts and they show a graphite throw out bearing as OE with a ball bearing style as an option and improvement. Has anyone run into this? I never knew there was anything like a graphite throw out bearing.
