Re: cub clutch question
Posted by screwstick on August 25, 2013 at 10:03:13 from (75.163.176.81):
In Reply to: cub clutch question posted by tedregentin on August 24, 2013 at 20:36:48:
Yes, I've done it many times. Get a genuine CaseIH replacement TOB, and soak it in a can of oil for a day or two, then pre-grease it with cheaper grease before you install it. If you have the clutch fingers adjusted correctly and the pedal free play adjusted right and you keep the TOB regularly greased, it'll last years and years.
