If your brother's tractor has the return from the loader valve in the transmission rather than the rear frame it should be changed to return into the rear frame as specified.
What can happen is the transmission will overfill and the rear frame will run low on oil. In some cases starvation of the hydraulic pump can result, the pump can fail due to oil starvation.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
