Re: FEL Hydraulics for 584
Posted by JimB2 on August 26, 2013 at 14:31:17 from (99.241.76.141):
In Reply to: FEL Hydraulics for 584 posted by Dodgerdoob on August 26, 2013 at 05:55:06:
Hi Justin,
See attached photo.
Remove item 39 pipe from top of remote hydraulic control valve to draft control unit under the seat. Cap off the connector at draft control connector. Connect the input hydraulic hose from loader controls to elbow on top of remote hydraulic control item 38, connect return line from loader control valve to drain plug under right rear axle using items 27, 28 and 29. My brother has a 3230 which is a newer model of the 584 and it has a plug into the side of the transmission just by the hydraulic control levers and we connected the hydraulic return line into this plug as it did not require the adapters item 27, 28 and 29.
Hope you understand this.
JimB
third party image
