Re: H won't start
Posted by JohnIH on November 30, 2000 at 08:53:52 from (162.27.9.20):
In Reply to: H won't start posted by Jim on November 30, 2000 at 08:41:27:
Anytime I see a carb leak gas it usually indicates it is overflowing inside due to a stuck float. The cold snap may have cause the float to stick due to condensation ice jamming it. I would clean out the carb and check the float and then put some deicer in the gas.
John
Post A Followup
: Re: Re: H won't start
