Around here you sure won't pull 13 foot of chisel plow with a 856. and you will work the snot out of it with 5x16's plus you will not be in high first or low forth . But go east of me eight miles then you can pull 5x16's with a stock 806 in forth low but three miles north of that ground you won't . I rented a farm one time that had been plowed with horses and a 8 N ford that pulled 2x12 inch plows when it was farmed then had free range cattle on it for 30-35 years before i got it . went to open it up with a late model 706 with the 291 gas and 4x16 710 semi mount plows and pulled the fast hitch off the tractor just sheared the bolts off the bottom . Replaced the bolt with grade 8 and had to add weight and plow in second low the first year to break the old plow sole that was three to four inches thick and as hard as black top. There were a lot of firsts for me at that farm.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
