Re: M Carb problems- Help!
Posted by randy red on November 30, 2000 at 12:17:58 from (165.95.106.196):
In Reply to: M Carb problems- Help! posted by Doug on November 30, 2000 at 12:00:42:
sounds like a govenor problem to me. Have you checked your linkage to see if it's hooked up? Also, I understand the weights can get stuck. In addition, your distributor advance could not be working. Basically, it sounds like your tractor runs fine at idle, but stumbles under load which is a sign of timing advance problem.
RR
Post A Followup
: Re: Re: M Carb problems- Help!
