Re: M overhaul advanced question--valve train
Posted by CNKS on August 31, 2013 at 19:07:57 from (216.144.104.128):
In Reply to: M overhaul advanced question--valve train posted by littlefarmer on August 31, 2013 at 18:30:48:
A machine shop should be able to measure and see if the cam needs turning or replaced, most are ok. You may need new cam bearings. Lifters are likely ok. You can take the rocker arms apart if you want to, I usually don't. I might clean the crud off with mineral spirits (sold as paint thinner). Pushrods just need to be straight, which you can see visually or rolled across the bench. The biggest problem is probably wear to the end of the rocker arms that does not allow the tappet measurement to be accurate. You may be able to get by with a narrow blade.
