M overhaul advanced question--valve train
Posted by littlefarmer on August 31, 2013 at 18:30:48 from (74.46.148.187):
I am overhauling the engine on my Farmall M. I would like to know what I need to check or replace on the valve train.
What should I check on the camshaft?
Should I replace the lifters?
Does the rocker arm assembly need to be disassembled and cleaned?
What do I need to check on the pushrods?
This is not a parade tractor. It is used to farm 160 acres. The last overhaul was in 1984 and it has done a lot field work. It will be doing more hard field work after the overhaul.
