Re: Super A axle pivot shaft
Posted by davset on September 01, 2013 at 10:25:53 from (24.177.226.188):
In Reply to: Super A axle pivot shaft posted by Charles Green on September 01, 2013 at 09:01:14:
Did you replace the pivot pin, or is it original?
It should have a notch ground in both ends of the pin to allow the clamp bolts to pass through the clamp holes AND lock the pin in place.
Knock the pin back out about an inch or so and you'll see one notch. Rotate the pin till the notch is on the bottom, then you can reassemble and the bolts should go through.
